Rather than creating another window in my project I created a container that becomes visible. This technique works find except now the end user has requested the container be movable. Is there a way I can make the container movable by the end user?
Yes, you should be able to work with the code from the draggable component example I posted here:
I would put a header across the container, and put the mouseMotion event code from that example into the header, but have it move its parent (the entire container).
