Move av component om a view from margin to margin regardless of the screen resolution
Want to move av component om a view from margin to margin regardless of the screen resolution.
View size 800 x 800 in designer.
We have Cordinate Container with a component which has a scaled binding from 0 -800 on the x position.
Cordinate Container is within a Flex container.
In designer the component which we want to move is relative to the real position at the plant floor.
When vi launch the URL on screen with 1920 resolution, the component which should be most right is now is approx. on the center.
Have also tried the View Canvas without success.
How to move a component from margin to margin regardless of the screen size and aspect ratio?
could you post a sample view of what you did and an image of what you want to achieve?
Case Solved :smiley:
