I copied a development Virtual Machine with Ignition 8.02 from an internal HDD to an external HDD. Now whenever I open a window (in Designer on the same VM) with OPC connections I get the errors in the attached screenshot and all objects show the RED color.
The OPC connection shows no fault and enabled.
I tried creating new objects with same results.
