MQTT BROKER.hivemq.com
I
I cannot connect the broker .hivemq.com to Ignition
10.128.244 isn't a valid IP address.
Which IP should I use
If you are connecting to HiveMQ Cloud, it supports only secure connections (MQTT TLS port 8883 and secure Websocket port 8884). In MQTT Engine, your connection string would look something like ssl://server.hivemq.com:8883 or ssl://1.2.3.4:8883. You’ll need to add authentication parameters HiveMQ provided.
okey, thank you bnakatani
