I have newly installed ignition gateway V8.3.
The MQTT Engine and Distributor are V5.00 beta 2.
I installed a new ignition edge with MQTT transmission module V5.00 beta 2. It can communicate with the V8.3 Gateway.
But when I tried to connect from an existing installed MQTT transmission module V4.0.15, the edge cannot connect with new V8.3 gateway.
Is it a version compatible issue?
Is there any ignition MQTT module compatible matrix table I can refer to?
Or another question, the edge ignition is V8.1.24, can I upgrade the edge MQTT transmission version to V5.00 beta 2?
