MQTT Engine 5.0.0 - SpB Filtered namespace
Hello, I am testing out Ignition 8.3 and have updated the MQTT Engine module to 5.0.0
I need to filter the sparkplug B namespaces in order to gain connectivity to our EMQX broker but when I use the filtered namespace attribute in the server settings it seems to only filter out “spBv1.0/#” but leaves “spBv1.0/STATE/IamHost”. Is there a way to filter this namespace as well?
Thanks!
Update: I was able to get around this by creating a new set that didn’t enable “Primary Host”.
If this was the solution, please mark the post that solved your problem, it will help anyone with the same issue in the future when they find your post.
I feel dumb. I can’t for the life of me figure out how to mark a post as solved. Mind pointing me in the right direction?
Perfect image choice :rofl: but unfortunately not seeing that as an option :man_shrugging:
Very strange, I've not seen that before...
The 3rd Party Modules category doesn't have the Solved plugin enabled.
Solved! :rofl:
