Hello,
Here my configuration.
- I have a Raspberry Pi 5 with Docker compose with
- Ignition 8.3
- PostgreSQL database
- Mosquitto (MQTT broker)
I’m able to connect the gateway to the server
I use the default server set.
The default namespaces are disabled (Elecsys, SparkplugA, SparkplugB and Xirgo), and a custom namespace “aircon” is created.
But here I’m not able to link the custom namespace to the server set.
Someone has the same issue ? It is a configuration error ? Or just a bug ?
I can wait the official release, it’s just annoying
Thank you !
Hey,
I’m running into the same error, was about to post, but came across this post while looking if there’s a solution/duplicate.
I’m leaning more towards it being a bug, as I am getting tags using the same configuration on 8.1.42
The server set was linked after a reboot of the gateway.
I can see the tag “Messages per second” change when I send a message, but no tags are created. I’m on the right topic “aircon/test”.
I tried to remove the wildcard on the namespace for just “aircon”. But the gateway seems to not change the subscription. So I restarted again the gateway, and the subcription was right. But same result, I can see the tag “Messages per second” change, but no tag was created.
I’ve created a support request on cirrus website. I will post their answer here
Updated to MQTT Engine 5.0.0-Beta2 and Ignition 8.3-Beta4, and still the same issue.
Waiting the cirrus support
