I'm trying change the history configuration in an UDT in MQTT Engine, I'm using a script, but I have this error: [Bad_AccessDenied("Insufficient Tag Provider Edit Permissions")]. I don't understand why, because I can change the configuration manually.
The MQTT Engine is a read-only tag provider. I typically use reference tags inside a UDT on a local tag provider to reference the tags in MQTT Engine and to set the local history configuration. If you need to change the history configuration on the MQTT Engine UDT, I believe you need to modify the history configuration on the MQTT transmission side, but honestly, you're better off using the reference tags and UDTs on a local tag provider instead which will give you full control.
I would reach out to CirrusLink support in this case. I was under the assumption those UDTs were read-only, and I suspect that if you do modify them, that you could run the risk that an MQTT Transmission publish/birth message could overwrite those back to defaults.
I need this for Store and Forward between Ignition Edge (with MQTT Transmitter) and Main Ignition (with MQTT Engine). For Store and Forward, is it necessary history in MQTT Engine for a good functionality or is it possible other way?
