Hi.
I’m investigating some MQTT server disconnection issues from the Engine server and I found the below exception recurring every single second. While data is arriving on the server it’s continuously throwing this error.
Ignition server 7.9.12, MQTT Engine and Transmission version 3.4.7.
What could cause it?
thanks
INFO | jvm 1 | 2019/09/03 13:04:57 | E [c.c.m.e.g.EngineCallback ] [13:04:57]: Failed to handle message on topic spBv1.0/dir01/NDATA/ips-edge-00005
INFO | jvm 1 | 2019/09/03 13:04:57 | java.util.concurrent.RejectedExecutionException: Task com.cirruslink.mqtt.engine.gateway.EngineCallback$$Lambda$863/62337317@308da7eb rejec
ted from java.util.concurrent.ThreadPoolExecutor@53a66e10[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0]
INFO | jvm 1 | 2019/09/03 13:04:57 | at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:2063)
INFO | jvm 1 | 2019/09/03 13:04:57 | at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:830)
INFO | jvm 1 | 2019/09/03 13:04:57 | at java.util.concurrent.ThreadPoolExecutor.execute(ThreadPoolExecutor.java:1379)
INFO | jvm 1 | 2019/09/03 13:04:57 | at com.cirruslink.mqtt.engine.gateway.EngineCallback.messageArrived(EngineCallback.java:174)
INFO | jvm 1 | 2019/09/03 13:04:57 | at com.cirruslink.chariot.client.CirrusClient.messageArrived(CirrusClient.java:546)
INFO | jvm 1 | 2019/09/03 13:04:57 | at org.eclipse.paho.client.mqttv3.internal.CommsCallback.deliverMessage(CommsCallback.java:477)
INFO | jvm 1 | 2019/09/03 13:04:57 | at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:380)
INFO | jvm 1 | 2019/09/03 13:04:57 | at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:184)
INFO | jvm 1 | 2019/09/03 13:04:57 | at java.lang.Thread.run(Thread.java:748)
