MQTT Engine / SparkplugB Namepsaces
I am working in a test environment, Ignition Maker 8.3.2, Cirrus MQTT Engine, EMQX MQTT broker.
My data is not refreshing, and I am seeing the following in the logs:
Indeed the MQTT Engine is publishing to both the UNC namespace and the “Edge Nodes” folder, however I had already disabled the “Default Tags Enabled” option several re-starts ago.
I’ve tried every combination of deleting tags, toggling the module enable/disable, removing / reinstalling the module but none of those things seem to fix it.
Any recommendations?
Consider posting this on the Cirrus Link forum.
Done. Thanks.
One thing that stands out to me is that you are editing the Sparkplug B namespace instead of creating a new namespace for your UNS tags. My guess is that it's still trying to publish the tags under the Sparkplug B namespace which is essentially a "reserved" or special namespace intended for Sparkplug B type messages. You'll want to create a custom namespace most likely and completely disable the Sparkplug B namespace.
