MQTT on new Edge Panel
Greetings,
With the new Edge line out, I am having an issue configuring/installing what I need to test and setup MQTT connection to a main gateway. I have downloaded the new 8.1.33 release, but when I try to install the "Panel" version that is supposed to have MQTT transmission included, I just get taken to an information page with no link.
Also, there is only Distributor and Engine modules and not the transmission module anymore...There is nothing in the gateway settings that help either.
What am I missing? Thanks!
You could try to manually download the latest MQTT Transmission module (4.0.18) here. Then manually install by going to -> Config -> Modules -> Install Module.
