I'm trying to configure MQTT connection to the MQTT server via Engine Module, but I'm getting errors.
Using MQTT.fx software I was able to connect to the MQTT server with no problems.
To be clear, you had to uncheck that because your broker has an SSL/TLS certificate that is missing hostname information in the standard location. It is not part of “normal” configuration.
