Hi all !
I am pretty new to MQTT , but i'm in kind of need to use it for a project i'm working on. This is the setup :
I have a Crouzet HMI with a Crouet EM4 PLC. I have enabled the MQTT on the HMI, and added a publisher to it with a few values to a test topic. I run a Mosquitto MQTT server on my windows computer. All is working fine, i use MQTTX on my windows pc to monitor the data and everything comes nicely in. But when i try to publish data from the MQTTX (or any other i tried) , the values don't get to the HMI subscriber. I tried with all different settings , of which none worked :
- I set the protocol version to 3.1 and 3.11
- I formatted the JSON exactly like it came in on the MQTT server
- I tried various different JSON formats (without brackets, without timestamp etc)
- Tried RAW data
This is an example of the test that has been posted from the HMI to the server , with a bit and a word as test
"d" : {
"PowerONOFF" : [ false ],
"Fan" : [ 0 ]
when i try to change the value for the Fan , it doesn't get there.
Anyone having any experience in this? Thanks allot for any help .
