MQTT Tag Alarm Configuration lost on gateway restart
I came back to work today after leaving a project running over the weekend and I was looking for the alarms that should have been generated over the weekend (devices running on simulation so alarms trigger every few minutes).
I was surprised to see there weren’t any alarms. Took me a while to realize that the alarms I had configured on the MQTT tags were gone. That is, the configurations I had made for those tags was gone. I tried again and restarted the gateway and the configuration disappeared again. Not sure if this is a bug or something I’m doing wrong. Any ideas?
I also have these tags configured as “historical”, but that configuration works fine. Only the alarm config disappears. I’m running Ignition 8.0.2 connected to an Edge Gateway. The Edge gateway is the one sending the MQTT data to the main gateway.
