Hey community,
I am trying to use MQTT Tags for my home Automation System iobroker.
The Ignition Gateway and iobroker running in Docker Containers on the same Ubuntu machine.
They are using macvlan both.
Unfortunately, I can't see the defined tags individually in the published messages.
Every time the value for one of the tags changes, it is displayed as one message.
The Transmitter is using the following Sparkplug config.
It is showing Device ID = ... instead of Tag = value.
When I publish directly from the MQTT Explorer it looks different.
On iobroker the messages look exactly the same.
What am I missing here?
Do you need more information?
Best regards,
Marcel
