There is a tutorial about cirrus, it mentions the extra exercise, that replace Non-TLS MQTT port 1883 with TLS MQTT port 8883, as below
At this point you have a fully functional system that can be expanded or modified as required. Below are some additional activities you may want to try on your own.
- TLS enable the MQTT Distributor module and disable port 1883
- Note production MQTT Infrastructures should never run on the open Internet without using TLS enabled MQTT connections!
after I tried, and adjust the setting on transmission tcp://xxx.xxx.xxx.xxx/8883, the connection is still off, can someone please advise how to solve it? thanks
