MQTT Transmission does not auto-publish newly created calculated tags
When I create a new Calculated Tag inside the default tag provider, MQTT Transmission does not automatically publish it to the MQTT broker. The tag only becomes visible in MQTT Explorer after I manually click Refresh in the Transmission Control folder.
This happens every single time a new Calculated Tag is added — whether I add one tag or an entire subfolder of tags.
In a production environment where Calculated Tags are added regularly by engineers who are not always aware of the MQTT refresh requirement, this creates a silent data gap — tags appear healthy in Ignition but are simply not publishing to the broker until someone notices and manually triggers the refresh.
Is their any way to auto refresh the tags?
This is the way the Cirrus Link modules work. It's because a lot of times, you want to wait to add a bunch of tags or whatever before you do the refresh.
You can add a script on the "Refresh Required" tag that automatically triggers the refresh.
wont that creat a load on gateway as it will scan and refresh after a specific timeperiod.
The Refresh Required tag only goes True when Transmission detects a structure change. So you'd script it such that when it goes True, you set the Refresh tag True.
