MQTT transmission server connection won't try to connect
I have an Ignition Edge system and the server connection wont connect. It stays at 0 of 0. Even though I have a connection defined.
Does anyone have any ideas as to why its doing that?
First stop would be the logs.. Second would be possibly to check to make sure that you have a Transmitter assigned to the Server Set that is targeting your Connection?
Nothing glaring in the logs and yes a server set is assigned to the transmitter. I disabled and enabled the transmitter and not its connected. Not sure why that worked but it did. Thank you for the help.
