MQTT Transmission with AWS IoT Endpoint
I am trying to setup Ignition MQTT Transmission to the AWS IoT Endpoint server with certificates and keys. I have followed the instruction as per the below link:
https://docs.chariot.io/display/CLD80/IBSNOW%3A+AWS+Quickstart
Topic: Edge Setup with Ignition and MQTT Transmission
I have checked that AWS IoT certificates and keys are working fine but still MQTT Transmission is not able to connect AWS IoT Endpoint server.
Please assist and let me know if you need any further information.
