I have installed ignition v8.1.26, but I didn't see the correct MQTT engineer and distributor for this version.
Instead I installed MQTT V4.0.15, which appears when I select Ignition V8.1.25.
Will it work?
Will it work?
The versions you described is the same combination I use with no issues.
This details what's compatible but seems like it hasn't been updated in a while.
https://docs.chariot.io/display/CLD80/Ignition+Compatibility+with+Cirrus+Link+Modules
Thanks for the info.
It's a new setup, maybe my setting is not correct. I will double check.
