Since Azure supports MQTT directly with its IoT Hub can you use the MQTT Transmission module to send data to Azure? I would like to setup an Ignition Edge MQTT device at a remote site that can send data to Azure MQTT. Then have an Ignition server somewhere else be able to connect to the Azure IoT hub using MQTT to read the data. According to Microsoft it is a standard implementation of MQTT so I feel like this should work. So far in my attempts I have not been able to make it work. I cannot seem to get Edge MQTT to connect to Azure. Has anyone done this successfully? Is it even possible?
Thanks!
