Setting up my first non Ignition IDP for a project.
The customer is using the Azure SAML IDP.
Ignition version is 8.1.7
We have everything setup in the gateway, and when I test the login from the gateway I get the following in the IdP response data tab:
No IdP Response Data
The IdP response data is unavailable. Check the logs for details.
If I take a look in the logs I have the following error from the WebAuthSessionImpl Logger.
Message: Unable to handle login response
com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterException: Unable to parse the WebAuthResponse from the HTTP request
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapter.parseAttributes(IdpAdapter.java:122)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.onLoginResponseInternal(WebAuthSessionImpl.java:199)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.lambda$onLoginResponse$2(WebAuthSessionImpl.java:220)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.mdc(WebAuthSessionImpl.java:108)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.onLoginResponse(WebAuthSessionImpl.java:220)
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterConfigRoutes$TestLoginWebAuthResponseHandler.handle(IdpAdapterConfigRoutes.java:301)
at com.inductiveautomation.ignition.gateway.auth.federation.FederationRoutes.callback(FederationRoutes.java:273)
at com.inductiveautomation.ignition.gateway.dataroutes.Route.service(Route.java:252)
at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupImpl.service(RouteGroupImpl.java:61)
at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupCollectionServlet.serviceInternal(RouteGroupCollectionServlet.java:59)
at com.inductiveautomation.ignition.gateway.dataroutes.AbstractRouteGroupServlet.service(AbstractRouteGroupServlet.java:38)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder$NotAsyncServlet.service(ServletHolder.java:1391)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:760)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:547)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:500)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:543)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:398)
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:161)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
Caused by: com.inductiveautomation.ignition.gateway.auth.web.strategy.WebAuthStrategyException: Unable to create the XML Attribute Source from the SAML Response
at com.inductiveautomation.ignition.gateway.auth.web.strategy.saml.SAMLWebAuthStrategy.parseWebAuthResponse(SAMLWebAuthStrategy.java:59)
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapter.parseAttributes(IdpAdapter.java:112)
... 52 common frames omitted
Caused by: com.inductiveautomation.ignition.gateway.auth.saml.binding.http.response.SAMLHttpResponseFactoryException: Unable to deserialize the SAML Response XML Document
at com.inductiveautomation.ignition.gateway.auth.saml.binding.http.response.AbstractSAMLHttpResponseFactory.create(AbstractSAMLHttpResponseFactory.java:414)
at com.inductiveautomation.ignition.gateway.auth.web.strategy.saml.SAMLWebAuthStrategy.parseWebAuthResponse(SAMLWebAuthStrategy.java:57)
... 53 common frames omitted
Caused by: com.inductiveautomation.ignition.gateway.auth.saml.serialization.SAMLDeserializerException: Unable to parse the Document
at com.inductiveautomation.ignition.gateway.auth.saml.serialization.AbstractSAMLDeserializer.deserialize(AbstractSAMLDeserializer.java:43)
at com.inductiveautomation.ignition.gateway.auth.saml.binding.http.response.AbstractSAMLHttpResponseFactory.create(AbstractSAMLHttpResponseFactory.java:412)
... 54 common frames omitted
Caused by: com.inductiveautomation.ignition.gateway.auth.saml.parsing.SAMLDocumentParserException: Expected one Signature candidate for signed node 0 and xPath /samlp:Response but got 0
at com.inductiveautomation.ignition.gateway.auth.saml.parsing.SignatureValidatingSAMLDocumentParserDecorator.getOnlyChild(SignatureValidatingSAMLDocumentParserDecorator.java:111)
at com.inductiveautomation.ignition.gateway.auth.saml.parsing.SignatureValidatingSAMLDocumentParserDecorator.validate(SignatureValidatingSAMLDocumentParserDecorator.java:124)
at com.inductiveautomation.ignition.gateway.auth.saml.parsing.SignatureValidatingSAMLDocumentParserDecorator.parse(SignatureValidatingSAMLDocumentParserDecorator.java:197)
at com.inductiveautomation.ignition.gateway.auth.saml.serialization.AbstractSAMLDeserializer.deserialize(AbstractSAMLDeserializer.java:41)
... 55 common frames omitted
Any ideas where to start? I don’t have admin access to anything with this customers Azure, so if I need to have them change anything I’ll need to be explicit. Or is there something on the Ignition side I need to do?
