MSSQL JDBC 13.2.1 JAR won't install on Ignition 8.3.2
On a fresh 8.3.2 install, when I try to add MSSQL jdbc JAR through the Databases→Settings Microsoft SQL Server then click the 3 dots & select Manage JAR files, I can add the JAR file, but when I try to Save Changes, I get ‘Error - 1/1 operations failed’ in the upper right hand corner, and the JAR file doesn’t get added. Also there’s nothing showing up in the logs even when selecting TRACE for all logger categories that have jdbc in them.
This did work on another Ignition platform that was upgraded from 8.1.? to 8.3.2 without complaint.
Any ideas where to look for the cause of this error?
Try the advice in this post:
