MSSQL Server Database Connection Error : Faulted
Hello ,
In trying to establish Database connection via MSSQL Server but getting the following error.
java.net socket timeout exception: receive timed out.
" Verify Server and Instance Names "
" Check Firewall blocking UDP traffic to port 1434"
Yes, that’s an error caused by something outside Ignition. The suggestions are not exhaustive, but are common causes.
If you didn’t read through this, I recommend it - Connecting to Microsoft SQL Server Express - Ignition User Manual 7.8 - Ignition Documentation
