Multi dropdown into SQL query. How to display array?
Hi there,
I'm trying to input a multi-dropdown (string) into SQL query, and display it in a table in Ignition.
The result looks like this:
And in igntion on the dropdown it looks like this:
Is there a smart way for how to display this nicely in the table? Do I need to concat the whole array, or is there a more elegant way?
The dropdown should look like this:
Ole and Melhus dropdown
And the options should look like this:
    "isDisabled": false,
    "label": "Ole",
    "value": 35
    "label": "Melhus",
    "value": 72
(I've given the employee number as 'value'. You could just repeat the names there.)
  • You pass the dropdown's value property to the SQL query.
  • You bind the table's data property to the SQL query.
You don't display the dropdown in the table unless you are trying to use a dropdown to edit a table. Please clarify.
I am using multiple choise dropdown, and if i select multiple names, the output is an array of names. I then want to write the values to sql, then display the values in a table.
I can concat all vales of array like this «Ole, Melhus, Robert», but I was hoping for a more elegant solution :grin:
Vanilla JDBC doesn't understand database columns that hold arrays. The JDBC drivers that do are brand-specific extensions. Ignition uses vanilla JDBC.
Allright, so I guess I need to concat the string?
Not sure how to do this efficiently though... This is not the best way :stuck_out_tongue:
concat(concat(concat({this.props.value}[0],", "),{this.props.value}[1]),", ")
Jython doesn't have a concat() function. Just use + to concatenate strings. Or, perhaps, use ','.join([some list]) to make a comma-delimited string of keywords.
Thanks, I didn't know i could concat using only +. This is the best I can do, which works in order to concat the values.
case(
    len({this.props.value}),
    0,	"Alle",
    1,	{this.props.value}[0],
    2, 	{this.props.value}[0] + ", " + {this.props.value}[1],
    3, 	{this.props.value}[0] + ", " + {this.props.value}[1] + ", " + {this.props.value}[2],
  	4, 	{this.props.value}[0] + ", " + {this.props.value}[1] + ", " + {this.props.value}[2] + ", " + {this.props.value}[3],
	5, 	{this.props.value}[0] + ", " + {this.props.value}[1] + ", " + {this.props.value}[2] + ", " + {this.props.value}[3] + ", " + {this.props.value}[4],
 	6, 	{this.props.value}[0] + ", " + {this.props.value}[1] + ", " + {this.props.value}[2] + ", " + {this.props.value}[3] + ", " + {this.props.value}[4] + ", " + {this.props.value}[5],
  	7, 	{this.props.value}[0] + ", " + {this.props.value}[1] + ", " + {this.props.value}[2] + ", " + {this.props.value}[3] + ", " + {this.props.value}[4] + ", " + {this.props.value}[5] + ", " + {this.props.value}[6],
 	8, 	{this.props.value}[0] + ", " + {this.props.value}[1] + ", " + {this.props.value}[2] + ", " + {this.props.value}[3] + ", " + {this.props.value}[4] + ", " + {this.props.value}[5] + ", " + {this.props.value}[6] + ", " + {this.props.value}[7],
    "Alle"
Problem is that even if i can write a string of names seperated by commas, the problem returns when i want to edit the table. When I click on a row, all editable cell values gets filled back into the dropdown, which don't support a string.... Hoping anyone can help me make this possible :slight_smile:
Maybe this must be done on the MySQL side? Maybe write all names into different columns, then concating all into 1 column when displaying the table? This was a tricky one :confused:
Oy!
The canonical way to do this sort of many-to-many relationship is additional DB tables, for the choice options and for the connections between subjects and choices. Assembled in results via LEFT JOIN operations.
Typically not editable within a table of subjects, but displayable there using your SQL DB's group_concat() function while grouping by subject.
To edit, typically a side view or popup would present the multi-select input and perform the appropriate inserts/deletes upon the "connections" table.
You will certainly want to get comfortable using jython scripts--expressions are not good tools to provide parameters to insert/update queries.
