In the process of trying to convert standard tag folders to UDT’s, the naming convention that we use cannot be replicated by using the Multi Instance wizard because of the space introduced between the Base Tag Name and the Tag Name Pattern. ie site 1 vs site1. Is there a way to circumvent/fix this issue?
No, but you can export one UDT instance to CSV and create more of them. That way you can make them outside of Ignition and import them in when done.
