Multi instances mistake
Good Morning
I have actually a UDT with 3 parameters : 2 integer and 1 string
When I go to use in multi-instance for some raison format is change in string ..
and all tags go in Error_configuration .
there is a Work around for this error?
What version is this on? I remember an issue in the past where a bunch of UDT parameters were changed to string type. It may or may not be related to what you are seeing as I was not using the multi-instance wizard. I haven't run into that issue on more recent 8.1.x versions.
My actually version is 8.1.16
I have update to 8.1.22 and now parametrs continute to be translated but tags are readed correctly
Sorry for digging up an old topic.
I'm working with version 8.1.35 and I encountered the problem described above.
All parameters given a value in the Wizard change their type to string.
Any ideas how to solve this?
Unfortunately, there is no solution with the wizard. Most people simply write a script that builds a list of tag definition dictionaries for system.tag.configure.
Hello
Thanks for fast answer.
I expected this. That's why my team suggested using a script.
However, I wanted to try this function for a smaller number of tags.
Actually, I just remembered that system.tag.configure also converts UDT parameters to strings. Where I've done this, I've used system.tag.configure to do everything except the parameters, followed by system.tag.writeBlocking to supply those.
In parallel, I corresponded with Support IA, who analyzed the operation of the Multi-instance Wizard.
It turned out that the problem I encountered in version 8.1.35 was solved in version 8.1.41 and later.
In the current version 8.1.42, parameter types do not change when creating an instance using the Multi-instance Wizard.
