Is there a way to make the tab strip “multi-layer”? This meaning one behind the other. The only way I see doing it is with two individual tab strips layered over each other. This tends to look kind of ugly.
Thanks for any advance help ![]()
Use the visibility function of the tab strips.
I could get you some example code to get you started if needed.
MP,
Did you try looking at the skeleton projects available in the designer?
Create a new project with the designer, then select one of the templates.
(I would advise doing this on a separate server from your production one, or at least using a separate tag provider from the one your other projects are using.)
There are two templates that have two-tier navigation and might help you to do what you wish. One of them has two-tiered tabs and looks pretty good to me.
