Multi-project usuarios
Good morning, I have a task related to the gateway, and three projects were created from it. All these projects are for the same client and are therefore related. The problem is that when I switch projects, it asks me to log in again. Is there any way to avoid this?
I've searched the forum, and there doesn't seem to be a solution, but the posts were old. Perhaps someone has found a solution recently. Thanks in advance.
This was my solution to that problem:
You might explore Single Sign On within your identity Provider and each of your projects… while it technically still authenticates each time, at least the login experience is improved for an end user.
Is this vision? If you use the retarget function to launch another project, you don’t have to relogin.
Great, very thanks. Yes, I'll look into how to work on it in the best way.
Ideally, I would have done it all in a single project, but I already had one set up. As for the type, it's in Perspective.
What I was able to do is switch between projects using Ignition's internal IdP, but if I exit and switch users, the project session remains open, which means I have multiple users within the "same" browser session.
