How can one multi-select objects in the report designer? I can select by dragging a box over the objects but if I have them on top of a larger object it gets selected too. I tried CTRL, SHIFT, ALT, and all combinations + click in the tree an in the design window, nothing seems to work.
alt+click works, but it also focuses the File dropdown in the designer, which screws things up unless you press esc after selecting. Less than ideal for sure.
I guess I didn't try that combination, thanks!
