I recently started using ignition, when i tried to customize multi state buttons (or any object that has the “customize style” option) the console gives me the following error, which haven’t occurred before i customized several multi-state buttons before but now the error keeps persistance:
I looked in the forum for similar questions but didn’t found any, if this was solved before please share the answer or link to topic.
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.inductiveautomation.factorypmi.designer.property.customizers.nstatebutton.EditPanel.<init>(EditPanel.java:94)
at com.inductiveautomation.factorypmi.designer.property.customizers.nstatebutton.NStateButtonCustomizer.initComponents(NStateButtonCustomizer.java:48)
at com.inductiveautomation.factorypmi.designer.property.customizers.nstatebutton.NStateButtonCustomizer.setObjects(NStateButtonCustomizer.java:30)
at com.inductiveautomation.factorypmi.designer.property.CustomizerDialog.<init>(CustomizerDialog.java:64)
at com.inductiveautomation.factorypmi.designer.property.propertytable.PropertyTablePanel.handleCustomizerAction(PropertyTablePanel.java:202)
at com.inductiveautomation.factorypmi.designer.model.CustomizerAction.actionPerformed(CustomizerAction.java:40)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
