I have string with ‘\n’ character. When I display it in a table, it shows as one line.
Is there a way to create multiline strings in a Perspective table?
Basically, no - you must use some other component(s) to achieve a break.
Not sure if you have solved this. I was facing the same issue. Managed to solved it by setting “whiteSpace” to “pre-line” under column style.
