I realize that I can point a project to a particular datasource by selecting it as the ‘Primary Datasource’. How can I utilize two different datasources for the same project?
Every query binding in FactoryPMI defaults to the “primary datasource” for the project, but you can simply select any of the other datasources on your gateway on a per-query basis.
hope this helps,
In other words, every project can use any datasource.
Thanks. So just to confirm if you want to point a ‘SQL Query’ to a datasource other than the primary one, you merely select that datasource from the dropdown at the top of the ‘Property Binding’ window. Is that correct?
You got it!
