Hello,
is it possible to configure the Gateway Scripting Project so that scripts in the project library of multiple projects can be accessed?
I want to add new functionalities to our global project. For this, I made a copy of the global project and I am using that for testing. I have some shared scripts in the copy- project that should be run when the value of a specific tag changes. How can I achieve this without changing the gateway scripting project?
Not as long as you have a test database as well. I have a separate db for my test gateway, and use a DNS name in the connection, so I don't have to change my DB connections when restoring a backup. You can see more on that here
