Is it possible that this cause an issue? I assume my software com.bowery.scada running in the same process with 3rd party module com.cirruslink.mqtt.engine.gateway, and they load different version of HikariCP
bowery@bf-bwi-1-ignition-1:/opt/bowery/robotics/ignition$ sudo find . |grep -i hikari
./data/jar-cache/com.boweryfarming.scada/__4016965787__HikariCP-2.3.2.jar
./data/jar-cache/com.cirruslink.mqtt.engine.gateway/__1047903372__HikariCP-java6-2.3.13.jar
I had a hiccup in my code
public class HikariConfig extends AbstractHikariConfig
static {
JavassistProxyFactory.initialize(); << ExceptionInInitializerError
does it make sense? if so, what workaround i should take?
