Have 2 docked navigation windows. The Left window will only display during specific times while the top navigation is always present.
How do I stop the left docked window from going under the top navigation or extending to dead space at top of left navigation if screen size is expanded? I want the top left of the Left navigation to be anchored to the bottom left of the top navigation.
Check your docking axis precedence and the overlap controls in your project settings under Vision => User Interface.
Did you configure different layer numbers for any of these windows?
I have tried with both having higher/lower/same Layer/dock index and doesn't seem to make a difference
Probably time to get support involved.
Solution was to adjust the Layout Constraints on the component (tab strip)
