If you have multiple network adapters with static IP addresses (or multiple IP addresses bound to a single adapter, not counting loopback), I would recommend that you manually specify which one FactoryPMI uses. This is a precautionary measure to eliminate confusion. To do this:
- Open the gateway configuration page
 - Select the Cluster page
 - Under the Advanced pane uncheck Autodetect Bind Interface
 - Under the Advanced pane type the IP address under Bind Interface. DNS addresses will work fine.
