Multiple SQL case statements
I am writing a SQL query that counts all of the errors that we logged between 2 dates. Unfortunately, some of the data in the table we are pulling from was logged incorrectly. To fix this, I tried to add some CASE statements into the SQL query to change the error name if it was logged before a specific date. The query I wrote works as intended, but it just seems to be a lot of CASE statements. Here is the code:
SELECT
		case
		when  :Startdate <= '2025-6-13 00:00:00' and Fault = 'Inline fill timed out' or  :Enddate <= '2025-6-13 00:00:0' and Fault = 'Inline fill timed out' then 'EOAT Mandrel Stripper Extend'
		when  :Startdate <= '2025-6-13 00:00:00' and Fault = 'Expected part present at shuttle' or  :Enddate <= '2025-6-13 00:00:0' and Fault = 'Expected part present at shuttle' then 'EOAT Mandrel Stripper Retract'
		when  :Startdate <= '2025-6-13 00:00:00' and Fault = 'Escapement slide 1 (upper) extend' or  :Enddate <= '2025-6-13 00:00:0' and Fault = 'Escapement slide 1 (upper) extend' then 'Inline fill timed out'
		when  :Startdate <= '2025-6-13 00:00:00' and Fault = 'Escapement slide 1 (upper) retract' or  :Enddate <= '2025-6-13 00:00:0' and Fault = 'Escapement slide 1 (upper) retract' then 'Expected part present at shuttle'
		when  :Startdate <= '2025-6-13 00:00:00' and Fault = 'Escapement slide 2 (lower) extend' or  :Enddate <= '2025-6-13 00:00:0' and Fault = 'Escapement slide 2 (lower) extend' then 'Escapement slide 1 (upper) extend'
		when  :Startdate <= '2025-6-13 00:00:00' and Fault = 'Escapement slide 2 (lower) retract' or  :Enddate <= '2025-6-13 00:00:0' and Fault = 'Escapement slide 2 (lower) retract' then 'Escapement slide 1 (upper) retract'
		when  :Startdate <= '2025-6-13 00:00:00' and Fault = 'Escapement part eject extend' or  :Enddate <= '2025-6-13 00:00:0' and Fault = 'Escapement part eject extend' then 'Escapement slide 2 (lower) extend'
		when  :Startdate <= '2025-6-13 00:00:00' and Fault = 'Escapement paret eject retract' or  :Enddate <= '2025-6-13 00:00:0' and Fault = 'Escapement paret eject retract' then 'Escapement slide 2 (lower) retract'
		when  :Startdate <= '2025-6-13 00:00:00' and Fault = 'Escapement part containment extend' or  :Enddate <= '2025-6-13 00:00:0' and Fault = 'Escapement part containment extend' then 'Escapement part eject extend'
		when  :Startdate <= '2025-6-13 00:00:00' and Fault = 'Escapement part containment retract' or  :Enddate <= '2025-6-13 00:00:0' and Fault = 'Escapement part containment retract' then 'Escapement paret eject retract'
		when  :Startdate <= '2025-6-13 00:00:00' and Fault = 'IV_1 sensor timed out' or  :Enddate <= '2025-6-13 00:00:0' and Fault = 'IV_1 sensor timed out' then 'Escapement part singulator extend'
		else Fault
		end as Fault,
		count(Fault) as count
FROM (SELECT Datetime,
		MachineID,
		Fault
		FROM AutomatedEquipmentFaultLog
WHERE MachineID = :MachineID  and Datetime BETWEEN  :Startdate and  :Enddate and Fault !=  'Bowl low parts' and  Fault != 'Inline fill timed out')q
GROUP BY Fault
ORDER BY count desc
I also want to avoid switching the actual table values if possible.
Is there a better way to write this query?
As in you want to avoid fixing the source data? That would be the obvious thing to do, to make querying it easier in general and not impact query performance
Yeah, I just want a quick fix for the time being. The long term will be to fix the source data.
There is no need for the sub query, and you can consolidate the date checking in the case.
SELECT
    CASE
        WHEN (:Startdate <= '2025-06-13' OR :Enddate <= '2025-06-13') THEN
            CASE Fault
                WHEN 'Inline fill timed out' THEN 'EOAT Mandrel Stripper Extend'
                WHEN 'Expected part present at shuttle' THEN 'EOAT Mandrel Stripper Retract'
                WHEN 'Escapement slide 1 (upper) extend' THEN 'Inline fill timed out'
                WHEN 'Escapement slide 1 (upper) retract' THEN 'Expected part present at shuttle'
                WHEN 'Escapement slide 2 (lower) extend' THEN 'Escapement slide 1 (upper) extend'
                WHEN 'Escapement slide 2 (lower) retract' THEN 'Escapement slide 1 (upper) retract'
                WHEN 'Escapement part eject extend' THEN 'Escapement slide 2 (lower) extend'
                WHEN 'Escapement paret eject retract' THEN 'Escapement slide 2 (lower) retract'
                WHEN 'Escapement part containment extend' THEN 'Escapement part eject extend'
                WHEN 'Escapement part containment retract' THEN 'Escapement paret eject retract'
                WHEN 'IV_1 sensor timed out' THEN 'Escapement part singulator extend'
                ELSE Fault
            END
        ELSE Fault
    END AS Fault,
    COUNT(Fault) AS count
    AND Datetime BETWEEN :Startdate AND :Enddate
    AND Fault NOT IN ('Bowl low parts', 'Inline fill timed out')
GROUP BY Fault
ORDER BY count DESC
Gave this a try and it seemed to work, and looks much cleaner. Thanks!
Is there any other ways I could optimize this query? Just trying to learn from my mistakes.
Not really.
I would set this up as an update query and fix the bad entries with a single execution. Though, my priority would be fixing the source data asap.
