Multiple styles in custom SVG
I have a custom SVG file with three different icons I would like to add.
Is there any way I can have different styles for each of my icons? Currently, the second two icons use the same style when they are both on the screen. Thanks.
the file you show seems like the 3 svg already have diffrent styles, what exactly is not working here?
tho it seems in the thrid one you are overwriting the style of the second one, there should probably be a different name for cls1 class.
im also not sure if you need the things here
You’re right. The problem was that the first style was being overwritten by the second. Changing cls1 worked! Thanks!
No problem,
Could you mark the solution so that it appears solved. So the forum and others dont need to check it again.
