In a Value Changed tag event script I have the following:
qual = currentValue.quality
print '_' * 50
print 'tag value changed: %s' % tagPath
print 'tag quality:', qual
if initialChange:
print 'Initial change'
The output in wrapper.log is:
INFO | jvm 1 | 2020/12/08 09:39:35 | __________________________________________________
INFO | jvm 1 | 2020/12/08 09:39:35 | tag value changed: [Dev2]Health
INFO | jvm 1 | 2020/12/08 09:39:35 | tag quality: Uncertain_InitialValue
INFO | jvm 1 | 2020/12/08 09:39:35 | Initial change
INFO | jvm 1 | 2020/12/08 09:39:35 | tag quality: Error_Configuration
Why do both events report they are InitialChange? Shouldn’t only the first one be?
What version of Ignition are you using? How are you triggering this?
Ignition 8.1
By restarting the gateway in Windows services
Okay, and is that a memory tag? Expression tag? I’m just trying to get a quick reproduction set up so I can create a ticket.
Also I have the following in the quality changed event on the same tag:
print '-' * 50
print 'My quality changed: %s' % (tagPath)
if initialChange:
pv = previousValue.value
pq = previousValue.quality
print 'previous val:', pv
print 'previous qual:', pq
cv = currentValue.value
cq = currentValue.quality
print 'current val:', cv
print 'current qual:', cq
and the output in this case is:
INFO | jvm 1 | 2020/12/08 10:51:47 | --------------------------------------------------
INFO | jvm 1 | 2020/12/08 10:51:47 | My quality changed: [Dev2]Health
INFO | jvm 1 | 2020/12/08 10:51:47 | previous val: None
INFO | jvm 1 | 2020/12/08 10:51:47 | previous qual: Uncertain_InitialValue
INFO | jvm 1 | 2020/12/08 10:51:47 | current val: None
INFO | jvm 1 | 2020/12/08 10:51:47 | current qual: Error_Configuration
Here it’s not indicating initial change but should be. Shouldn’t it?
Also on 8.1 and restarting gateway.
Yes, something seems broken to me. I’m writing this up.
Can I subscribe to be notified on updates to this somehow?
This thread is linked to in our ticket, I’ll leave a note to come back and update once something is found/fixed.
Hello iamthebull, quality changed events have been updated to properly show the initial change flag after gateway restart. This fix will be in 8.1.3.
The value changed tag event issue is still being looked at. We’ll reply again when it is addressed.
Any update on the change tag event issue? How can the functionality be expected to operate in the current stable version?
