How can multiple properties of an OPC tag be dropped into a template? I would like to drop a tag value, tag name, tag path, tag max value and tag min value. Similar to when a tag is dropped into a normal window.
Any suggestions?
Any suggestions?
With UDTs you have to bind each property separately. We don’t have the same drag and drop since you are binding to properties of the UDT not tags.
