Multistate indicator not binding correctly
Hey, I've got a simple window that's throwing an error in the multistate indicator property binding.
Here's the XML.
window.xml (37.2 KB)
Everything looks correct inside the XML and the only change here from a project that worked should be 'changing the tags the tank binds to and its position'.
Is this the same as over here?
If so, don't double post. This is against this forum's rules.
If you don't get an answer on a post within several days, it is appropriate to add a "ping" comment to the original post. If you are in a hurry, open a support ticket.
It's slightly different, the old post was incorrect in symptoms and had the wrong XML, so I've flagged a mod to delete it.
If it would have been more appropriate to edit that post instead, I will do so in the future -- I'm used to forums where delete/add is the norm though, my apologies
Yes, do. This forum keeps edits visible, so there's no misunderstandings.
Will do in the future, and apologies again!
Didn't intend to spam
Any ideas on the object level?
The expression on the state property doesn't match the tank name. (Cylindical Tank vs Cylindrical Tank 1
Where are you seeing Cylindrical Tank 1 in the xml?
This is what I see when i import your xml into a new window.
It removed the listener/binding from the multistate because Cylindrical Tank didn't exist.
Hmmm, ok -- why is the name of the tank changing?
Beats me. lol.
Seriously, I tried changing the name to Cylindrical Tank Test in the XML and it imported as Cylindrical Tank Test 1
So, offhand, I believe this is a bug on setting items from XML. Can you post an export of the window instead?
When I export the window, the expression just comes out as blank
Try importing this one. You'll need to update the tank bindings.
Leor_test_2025-02-24_1318.zip (9.2 KB)
Tried a new setup
deviceconnupdate_2025-02-24_1044.zip (9.6 KB)
Now finding a new odd error involving null prop names?
(Your import works, but I'm wondering why my process to generate those bindings isn't working)
Here's my new XML: @JordanCClark any ideas?
deviceconnupdate_2025-02-24_1137.zip (9.6 KB)
I've run through a bunch of improvements to now end up with the following XML:
nwindow.xml (25.5 KB)
It should just have the expression bindings for tank value and capacity changed (according to my internal differ,
Changes in o:
  • Removed: capacity expression binding to 10000
  • Added: capacity expression binding to {[default]Local_Tags/A1}+{[default]Local_Tags/A2}
  • Removed: value expression binding to {[default]1_A1-1_A10/1_A1}*{[default]1_A1-1_A10/1_A2}
  • Added: value tag binding to [default]Local_Tags/A1)
But I'm now seeing a deserialization error.
@pturmel @JordanCClark any ideas?
  • I would make this into a template
  • Properties within the template components should point to tags using indirect addresing.
  • Top level parameters of the template hold just enough info to drive the indirect tags.
