Is there a way to add a custom variable in the text portion of a multi-state indicator?
For example:
<html><center>myVar<br><center>Cycle Stop
Where myVar would be tied to a custom property
For example:
Sure. By default, the Multi State Indicator uses the Style Customizer to set up the different states. If you look into the advanced component properties (you may need to change the property editor’s filtering settings) you should see a Styles dataset property. That dataset defines the different styles on the component:
Cell Update Binding on the styles dataset itself:
