(for ApexCharts) I think this should be:
formatter: (value, context) => value
I couldn't get it working with value.y or with the return (, and context is optional)
Pretty sure if you include the return keyword in an arrow function in Javascript, you have to add brackets.
formatter: (value, context) => { return value.y }
If you don’t want to use brackets, then don’t use the return keyword ![]()
Obviously, as soon as you want to do more complex stuff, such as a multi-line functions or stuff like that, brackets are mandatory.
100%
That linked post was from before the rewrite of the scriptable options parser:
Kind of a weird situation that I am just seeking some guidance on.
We allow the users to choose between light and dark themes.
The only thing I can’t seem to nail down is how to cause the charts to re-render in order to load the CSS assigned using the “var(--label)” settings?
ChartJS ver 3.0.0
First, 3.1.0 has improvements related to how the chart references CSS properties from it's parent, so you should check that out.
Secondly, yeah using CSS variables with Chart.js is a pain because it's canvas based.
Chart.js has no idea that it needs to re-render when its computed style changes.
You can work around it with a custom plugin. This currently needs to be applied per-chart, unfortunately.
The idea is:
props tree).props tree change will cause the chart to re-evaluate the CSS variables and re-render.I'm very open to suggestions on how to improve this, it's a PITA. Does anyone know a way to listen to changes of an element's computed style that doesn't involve polling?
// plugins[0].install
(chart) => {
if (this._theme_observer) {
this._theme_observer.disconnect()
const onCssChange = (callback) => {
const observer = new MutationObserver((mutations) => {
for (const mutation of mutations) {
for (const node of mutation.addedNodes) {
if (
node.tagName === "LINK" &&
node.rel === "stylesheet"
callback(node);
observer.observe(document.head, { childList: true })
return observer
this._theme_observer = onCssChange((element) => {
this.store.props.write('theme', element.href)
// plugins[0].uninstall
(chart) => {
Hey @bmusson, I feel like we should make a wiki for chart.js like for Phil's Integration Toolkit, containing examples of how to do things with an evolving contents list at the top. Did you want to start the topic and I can fill it in if you want (I'll just copy paste Phil's and reword)?
Sure, here we go:
Hey @bmusson, a colleague is having an issue with the chart.js component where the chart doesn't render on page load sometimes. What diag info would you need to diagnose?
e.g. the white space here is supposed to show a chart.js chart:
I actually just found this issue as well on a chart the other day, does yours render if you navigate out then back to the page?
I think so, or I think if you resize the page as well. I'd have to check with my colleague
Sounds a lot like the issue I am having.
Press F12 on chrome and checkout console for the error.
This kind of problems mostly happen when user use JavaScript code in the props of the chart.
Ah yes, i'll have a look tomorrow, cheers!
Yeah, checking the console out for error messages is the first step.
I am having an issue with bringing the module in and having it enabled in 8.3
It installs and after the gateway restart the status is “Inactive” When I try and enable I get a message. “Module Failed to Enable“
In the gateway logs I get the follow messages
ERROR
ModuleInstallRoutes
13Oct2025 13:36:17
Error enabling module `com.mussonindustrial.embr.charts`
WARN
ModuleManager
13Oct2025 13:36:17
Module 'com.mussonindustrial.embr.charts' cannot be enabled
Anyone else have this issue with 8.3.0?
Might be a silly question, but are you installing the 8.3 version?
Yes - Embr-Charts-Ignition83-3.1.0.modl
This is in a Docker Container - if that matters at all?
Do either of the errors in your log have a stack trace attached?
No there is no extra logs on those errors.
What version of Ignition?
I've just tested with a new 8.3.0 docker container and things appear to be working.
