Musson Industrial’s Embr v2027 Beta Modules
This thread is for updates and feedback related to Embr and the Ignition 2027 Betas.
Automatic publishing has been enabled for the 2027/main branch and module downloads are now available on GitHub.
Migration was pretty simple, I don't foresee many issues between 8.3 and 2027.
A sneak peak for the folks lurking around here...
Patch Notes
(Client Resource) Upgrade the TypeScript editor with a project-wide TypeScript language service.
  • Accurate, type-aware syntax highlighting for TypeScript and TSX.
  • Completions across client resources, with automatic imports, and completions for @/ resource paths and system: modules in imports.
  • Ctrl+click (or F12) goes to a definition, in this resource or another, including the resource an import names.
  • Hover information, signature help, symbol highlights and Find References (Shift+F12).
  • Type checking across resources, typed against the DOM, React, Periscope's system modules and Perspective's client library (the PerspectiveClient global, and perspective.context). Type errors are reported but never block saving.
  • Quick fixes (Alt+Enter), Organize Imports (Shift+Alt+O), Format (Shift+Alt+F), and inline find and replace (Ctrl+F / Ctrl+R).
  • An outline of the resource's declarations, Go to Symbol across resources (Ctrl+T), inlay hints for types and parameter names, automatic closing and linked renaming of JSX tags, and formatting as you type (on ;, } and Enter).
  • The Run JavaScript action's script editor gets the same language features, checked as JavaScript, with self typed as the component's ComponentStore.
  • Imports the browser can't load, such as react or other packages, are reported as errors; type-only imports of their types are allowed.
  • import { resource } from 'system:periscope' now loads the resource function instead of undefined.
