its my first time downloading Launcher and when I open it then select "add designer"
and select the Gateway. So, when open the designer nothing happens.
and this is my logs
log.txt (2.9 KB)
Is there a project on the gateway?
No, it didn`t even open.
What output do you get if you copy and run the long command from the logs directly in a terminal?
C:\Users\AL-FAJR\.ignition\cache\resources\runtimes\17.0.8\bin\java.exe -classpath C:\Users\AL-FAJR\.ignition\cache\resources\platform\launchclient.jar\00000000887A036A\launchclient.jar -Djavaws.sr.gateway.addr.0=http://localhost:8088 -Djavaws.sr.launchts=1699389567882 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M --add-opens=java.desktop/java.awt=ALL-UNNAMED --add-opens=java.desktop/java.awt.event=ALL-UNNAMED --add-opens=java.desktop/javax.swing=ALL-UNNAMED --add-opens=java.desktop/javax.swing.tree=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf.basic=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf.synth=ALL-UNNAMED --add-opens=java.desktop/javax.swing=ALL-UNNAMED --add-opens=java.desktop/javax.swing.tree=ALL-UNNAMED --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-exports=java.desktop/com.apple.eawt=ALL-UNNAMED --add-exports=java.desktop/com.sun.awt=ALL-UNNAMED --add-exports=java.desktop/com.sun.java.swing.plaf.windows=ALL-UNNAMED --add-exports=java.desktop/sun.awt=ALL-UNNAMED --add-exports=java.desktop/sun.awt.image=ALL-UNNAMED --add-exports=java.desktop/sun.awt.shell=ALL-UNNAMED --add-exports=java.desktop/sun.awt.windows=ALL-UNNAMED --add-exports=java.desktop/sun.swing=ALL-UNNAMED --add-exports=java.desktop/sun.swing.plaf.synth=ALL-UNNAMED --add-exports=java.desktop/sun.swing.table=ALL-UNNAMED --add-exports=java.desktop/sun.print=ALL-UNNAMED --add-exports=java.base/sun.security.action=ALL-UNNAMED -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
No, does a project even exist on the gateway webpage at Config/System/Projects?
