Not so bad stats I guess. I wonder what to do if memory usage goes too high.
You need to change the ignition.conf configuration to allow it to use more memory.
wrapper.java.maxmemory=4096
Just add this to ignition.conf file.
In case it's not obvious, the memory will rise and fall. The trend should look like a saw tooth.
