MySQL 5.7 Help
MySQL 5.7 Help
Some basic information:
Ignition 7.6.3 (b2013090513) 64-bit
SQL Bridge Module Details
Description An OPC-to-SQL data logger, transaction manager, and SQLTags historian
Version 5.6.3 (b2013090513)
Activation Mode Activated
New database:
MySql 5.7.1-m11-log
Community server Compiled for Win64 (x86_64)
Using port 3307
Old database:
MySQL 5.0.45-community-nt
Community Edition (GPL) Compiled for Win32 (ia32)
Using port 3306
Both databases reside on the same remote server. Connection to the remote server is over Satellite internet.
Ping statistics for x.x.x.x:
Packets: Sent = 46, Received = 46, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 659ms, Maximum = 1170ms, Average = 766ms
I have an alternate connection over a cellular modem that both connections work properly, however, the cellular connection is not always available where the mobile unit travels to. Therefore I need to ensure that the satellite link is as robust as possible because it will be the primary link to the database.
The issue that I am having is that ignition is not connecting to the new database over the satellite connection. The old data base connects correctly. The only think I can think of is that the latency of the connection is causing the database connection/login to time out. I have compared the two DB settings and they are almost exactly the same where the network and connection timeouts are concerned. IS there any way either editing the configuration of the DB or Ignition to increase the time allotted for the connection? The usual amount of data is approximately 64b of data per transaction.
Thank you in advance,
Andrew
The error that I am receiving is:
org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Communications link failure due to underlying exception: ** BEGIN NESTED EXCEPTION ** java.net.ConnectException MESSAGE: Connection timed out: connect STACKTRACE: java.net.ConnectException: Connection timed out: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at java.net.Socket.(Unknown Source) at java.net.Socket.(Unknown Source) at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:173) at com.mysql.jdbc.MysqlIO.(MysqlIO.java:268) at com.mysql.jdbc.Connection.createNewIO(Connection.java:2745) at com.mysql.jdbc.Connection.(Connection.java:1553) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:285) at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38) at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294) at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1247) at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1221) at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880) at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:194) at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:150) at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.run(DatasourceManagerImpl.java:1103) at java.lang.Thread.run(Unknown Source) ** END NESTED EXCEPTION ** Last packet sent to the server was 62 ms ago.)
org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1225)
com.mysql.jdbc.CommunicationsException: Communications link failure due to underlying exception: ** BEGIN NESTED EXCEPTION ** java.net.ConnectException MESSAGE: Connection timed out: connect STACKTRACE: java.net.ConnectException: Connection timed out: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at java.net.Socket.(Unknown Source) at java.net.Socket.(Unknown Source) at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:173) at com.mysql.jdbc.MysqlIO.(MysqlIO.java:268) at com.mysql.jdbc.Connection.createNewIO(Connection.java:2745) at com.mysql.jdbc.Connection.(Connection.java:1553) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:285) at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38) at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294) at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1247) at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1221) at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880) at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:194) at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:150) at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.run(DatasourceManagerImpl.java:1103) at java.lang.Thread.run(Unknown Source) ** END NESTED EXCEPTION ** Last packet sent to the server was 62 ms ago.
com.mysql.jdbc.Connection.createNewIO(Connection.java:2820)
