Hi All,
Does anyone know that ignition V7.9.9 is compatible with MySQL 8.0 or not?
Hi All,
It should be.
From https://inductiveautomation.com/downloads/fullchangelog/534 :
Added compatibility with MySQL 8.0 to new installs
Thank you Ethomason, Let me check it.
On existing systems that upgrade to 7.9.9, you would need to follow the steps mentioned on the following Knowledgebase article to get MySQL 8.0 working: Connection Errors when configuring MySQL 8.0 Database in Ignition – Inductive Automation Help Center
