Just this past Friday the database connection was reported as faulted. Up till then my Ignition application has been working perfectly and there have been no recent changes or updates. Looking at the Gateway it indicated MySQL connection was lost. Opened MySQL diagnostics and found this report. I tried to restart MySQL but this report is regenerated each time.
Any suggestions?
2017-05-30 06:10:49 - Starting server…
2017-05-30 06:11:02 - Server start done.
FROM DPE-D-GYSNBZ1.err:
2017-05-30T11:10:59 0 Warning TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2017-05-30T11:10:59 0 Warning ‘NO_ZERO_DATE’, ‘NO_ZERO_IN_DATE’ and ‘ERROR_FOR_DIVISION_BY_ZERO’ sql modes should be used with strict mode. They will be merged with strict mode in a future release.
2017-05-30T11:10:59 0 Note C:\Program Files\MySQL\MySQL Server 5.7\bin\mysqld.exe (mysqld 5.7.13-log) starting as process 9172 …
2017-05-30T11:10:59 0 Note InnoDB: Mutexes and rw_locks use Windows interlocked functions
2017-05-30T11:10:59 0 Note InnoDB: Uses event mutexes
2017-05-30T11:10:59 0 Note InnoDB: _mm_lfence() and _mm_sfence() are used for memory barrier
2017-05-30T11:10:59 0 Note InnoDB: Compressed tables use zlib 1.2.3
2017-05-30T11:10:59 0 Note InnoDB: Adjusting innodb_buffer_pool_instances from 8 to 1 since innodb_buffer_pool_size is less than 1024 MiB
2017-05-30T11:10:59 0 Note InnoDB: Number of pools: 1
2017-05-30T11:10:59 0 Note InnoDB: Not using CPU crc32 instructions
2017-05-30T11:10:59 0 Note InnoDB: Initializing buffer pool, total size = 8M, instances = 1, chunk size = 8M
2017-05-30T11:10:59 0 Note InnoDB: Completed initialization of buffer pool
2017-05-30T11:11:00 0 Note InnoDB: Highest supported file format is Barracuda.
2017-05-30T11:11:00 0 Note InnoDB: Log scan progressed past the checkpoint lsn 236924383454
2017-05-30T11:11:00 0 Note InnoDB: Doing recovery: scanned up to log sequence number 236927666988
2017-05-30T11:11:00 0 Note InnoDB: Database was not shutdown normally!
2017-05-30T11:11:00 0 Note InnoDB: Starting crash recovery.
2017-05-30T11:11:00 0 Note InnoDB: Starting an apply batch of log records to the database…
InnoDB: Progress in percent: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 2017-05-30T11:11:01.438619Z 0 [ERROR] I [truncated, 405 bytes total]
2017-05-30T11:11:01 0 Note InnoDB: Page dump in ascii and hex (16384 bytes):
len 16384; hex a422a4f20004f7780004f777000003bc0000003729cb610a45bf000000000000000000000057000503a9801500000000038400020011001300000000000000000000000000000000005d00000000000000000000000000000000000000000100020046696e66696d756d0008000b000073757072656d756d [truncated, 48.1 KB total]
InnoDB: End of page dump
2017-05-30T11:11:01 0 Note InnoDB: Uncompressed page, stored checksum in field1 2753733874, calculated checksums for field1: crc32 2964787571/239699844, innodb 1527697333, none 3735928559, stored checksum in field2 922854125, calculated checksums for field2: crc32 2964787571/2396998 [truncated, 473 bytes total]
InnoDB: Page may be an index page where index id is 93
2017-05-30T11:11:01 0 Note InnoDB: It is also possible that your operating system has corrupted its own file cache and rebooting your computer removes the error. If the corrupt page is an index page. You can also try to fix the corruption by dumping, dropping, and reimporting the co [truncated, 451 bytes total]
2017-05-30T11:11:01 0 ERROR] [FATAL InnoDB: Aborting because of a corrupt database page in the system tablespace. Or, there was a failure in tagging the tablespace as corrupt.
2017-05-30 06:11:01 0x2204 InnoDB: Assertion failure in thread 8708 in file ut0ut.cc line 920
InnoDB: We intentionally generate a memory trap.
InnoDB: Submit a detailed bug report to http://bugs.mysql.com.
InnoDB: If you get repeated assertion failures or crashes, even
InnoDB: immediately after the mysqld startup, there may be
InnoDB: corruption in the InnoDB tablespace. Please refer to
InnoDB: http://dev.mysql.com/doc/refman/5.7/en/forcing-innodb-recovery.html
InnoDB: about forcing recovery.
11:11:01 UTC - mysqld got exception 0x80000003 ;
This could be because you hit a bug. It is also possible that this binary
or one of the libraries it was linked against is corrupt, improperly built,
or misconfigured. This error can also be caused by malfunctioning hardware.
Attempting to collect some information that could help diagnose the problem.
As this is a crash and something is definitely wrong, the information
collection process might fail.
key_buffer_size=8388608
read_buffer_size=20480
max_used_connections=0
max_threads=151
thread_count=0
connection_count=0
It is possible that mysqld could use up to
key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 51702 K bytes of memory
Hope that’s ok; if not, decrease some variables in the equation.
Thread pointer: 0x0
Attempting backtrace. You can use the following information to find out
where mysqld died. If you see no messages after this, something went
terribly wrong…
13f96ab42 mysqld.exe!my_errno()
13fd0ef09 mysqld.exe!my_wildcmp_mb()
13fd0de00 mysqld.exe!my_wildcmp_mb()
13fa6bd88 mysqld.exe!?reserve@?$vector@EV?$allocator@E@std@@@std@@QEAAX_K@Z()
13fa6bfa1 mysqld.exe!?reserve@?$vector@EV?$allocator@E@std@@@std@@QEAAX_K@Z()
13fb7eb50 mysqld.exe!?reserve@?$vector@EV?$allocator@E@std@@@std@@QEAAX_K@Z()
13fa92c4f mysqld.exe!?reserve@?$vector@EV?$allocator@E@std@@@std@@QEAAX_K@Z()
13fa36574 mysqld.exe!?reserve@?$vector@EV?$allocator@E@std@@@std@@QEAAX_K@Z()
779459cd kernel32.dll!BaseThreadInitThunk()
77b7a561 ntdll.dll!RtlUserThreadStart()
The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains
information that should help you find out what is causing the crash.
2017-05-30 06:11:03 - Checking server status…
2017-05-30 06:11:03 - Trying to connect to MySQL…
2017-05-30 06:11:03 - Can’t connect to MySQL server on ‘127.0.0.1’ (10061) (2003)
2017-05-30 06:11:03 - Assuming server is not running
